3d drops
  • Thread starter Thread starter Brethil
Brethil
I have a problem; I designed a concrete tank full of water (static) and should create a set of drops (static) which, once inserted duly in the axieme file; They seem or make it look like a myriad of nice water drips fall into the so-called tank! ! !
:eek:
I tried to make some drops, but my ones are really worth it; could someone give me a tip?
I want for attempts.
thanks in advance :smile:
:eek:
Maybe you make it by creating the volume corresponding to the "rain" area and by associating it with the material "water"... or you create a new material starting from that and changing it according to your preferences. . .
is what I'm already doing, but the results are not that they are encouraging, I hope to find some better textures of bubble water...or some set of drops in 3d...
thanks for the advice cmq.
_
I'll throw them...
and search on the web a photo of drops on glass, editarla con gimp and create a transparent material by sticking the new texture?
I'll throw them...
Thank you, I solved by looking for decent textures on the net and sticking them to a solid; x now I have a "true almost rain"... but for work now it's more than good.
thanks again for availability
