3D sketch and sheet metal
  • Thread starter Thread starter qui
qui
Hello, everyone.
I have a "special" question: If I have a 3d sketch, which represents a "svergolata" sheet (returned), can I use the functions of sheet metal? and in turn, can I use flat repetition?
In practice I find myself in the situation that the blue slide does not lie on a floor, but only 3 of the four edges lie on a same floor. How can I solve the problem?
My goal is to calculate the spread of the sheet, nothing more.
steak
I will be synthetic:
2 floors (created with 3 points each)
2 sketches turned into flat surface
1 surface union
1 thickening
1 converts to sheet metal
to tell you more (and if how much I recommended is applicable) I need the file...
simplistically, bending with loft. :smile:
thanks to both for the suggestion, which I only tried tonight.
The fold with loft doesn't work, I've tried it before.
The other one came to some point, then I couldn't move on.
perlater are also bound to the position from the side walls.
3d and with sw2011.
and the design I didn't do it, my task is only to pull out the tracks for the sheet cutting.
But, did you look at the file I posted?? ?
I'd say yes, but I probably got two wrong sketches. . .
I'm trying now with another slide, formally analogous, but this prorium doesn't want to come? Why?
Thank you so much... I'm pretty bad.. .
I'm trying now with another slide, formally analogous, but he does not want to come? Why?
How not?
Yes, it comes! Did you look at your file that I put you on top? ?
Marco:smile:
Boh. I don't know what to say. I tried a few times the same way... and I didn't go... I tried a third... and now it works... .
Maybe I need vacation.
I don't know what to say. I tried twice and it didn't work... I tried a third and went... .
Maybe I need vacations
steak
steak
It's important to select the individual sketches, you have to try
select them more or less in the same area, better if from the Principality
segment.
Do some evidence and you can see it yourself.
