3d sketch conversion for fem analysis
  • Thread starter Thread starter horza
horza
Hello everyone,
I have a small problem in exporting a 3d sketch in iges to do a fem analysis with the abaqus software, I practically realized the sketch for a tubular frame when I remove the file in iges format when I go to open it in a fem software I also care about the lines of half-work and construction I wanted to know if during the export there was a procedure to avoid such inconvenience.
p.s. the sketch was made in this way, first the structure was created by means of lines of half-way then the points of interest were connected by line.
thanks infinitely
I did some tests a while ago, but I gave up. My path was against you, but there was no way to do it.
do a set, put the part with the basic sketch and a new part. in the new part copy the sketch lines you need to change it in the context of the axieme.
then save the new part as iges.
Maybe it's a bit too complicated than canceling a couple of lines from abqus.
