3d solid export in iges format
  • Thread starter Thread starter desMoira
desMoira
I need urgently to export a 3d set in a format compatible with pro-e, usually amount in inventor and carry out in iges from there.
I ask you guru: do you know if there are other methods/forms?? :confused:
a variant would be to use rhino, but it is a bit more slender.
I've seen you're using catia, why don't you take the conversion?
solved... I read that the autocad mechanical export to iges has it by default :biggrin: , and I used that!
I have the problem that now sees the solids but nn has plans and other geometric elements of reference for the assieme and for the views... but this is another story. Thank you!
Then say that you also have mechanical!!
Could you make dwg to iges conversions on commission?
