maxopus
now we see the supporter of the god b-rep what pulls out:biggrin:I told you he would turn to thunder and lightning
the fact that you are not a mechanical designer we take it as a mitigating.I asked for advice since mechanics and design not and my scope.(I am last year microbiology and genetics) which does not center with my pasion for particular motorcycles.this of the frame was and and a dream.but seen the answers "myceable" and "intiligent".I understand that my place is not here.
If you go zero to, like, 500 bars, but if you stay between 100 and 300...What a witty...
by memory, the compressibility of the oil is about 0.35% of the volume every 100 bar.
That I'm not exactly zero...![]()
the problem is also the flexibility of the plant components: pipes, piston seals, etc. on small volumes of oil such as those contained in such a plant could be sensitive.If you go zero to, like, 500 bars, but if you stay between 100 and 300...
:smile:
0.35% every 100 bar, so between 100 and 300 are 200 delta bars, which makes 0.70%If you go zero to, like, 500 bars, but if you stay between 100 and 300...
:smile:
As much as I have seen, the problem is more about large volumes of oil.on small volumes of oil like those contained in such a plant, this could be sensitive.
Look, if we have to get along, there are rules you have to respect!0.35% every 100 bar, so between 100 and 300 are 200 delta bars, which makes 0.70%
and anyway.. When I don't use something, why should I keep it under pressure? It's obvious I'm unloading at zero bar!
My "obvious mister", if the compressibility is in "percentage", would seem clear, logical. Lapalissian that with greater volumes the phenomenon is more marked.As much as I have seen, the problem is more about large volumes of oil.
cylidrins of large alesaggio have problems greater than those small
and the phenomenon is even higher when the cylinder is all extracted (volume of the room greater)
Who are you?but you are really bad...... you made him run away
But I didn't think I was so brutal, I normally can be much worse even in the morning greetings.But if he's gone... this job doesn't do for him.
It must be read in the gums before saying![]()
I meant: if the gasket deforms and increases the volume of the room of 2 mm^3, the percentage effect is as much as small the total volume of oil.cylidrins of large alesaggio have problems greater than those small
have you read the book of history saburo sakai? illuminating!the only thing that can do such a "sensitive" person is to comb the dolls.
I don't know what happened, but I think the educative modes of our days are getting out of a rambling band (not all fortunately).
We should learn something from our Japanese brothers and sisters in terms of rigor and dignity.
Here we only need someone to invoke the intervention of the mother or older brother and then we completed the work.
but once it didn't take the justification signed by the cad3d administrator to "scancellate"? Now was the "powder my account" box added? however it had registered with name and surname, maybe we can persecute it further on fb!Here we only need someone to invoke the intervention of the mother or older brother and then we completed the work.
You bastard!but once it didn't take the justification signed by the cad3d administrator to "scancellate"? Now was the "powder my account" box added? however it had registered with name and surname, maybe we can persecute it further on fb!
