3ds max 2016 render problem
  • Thread starter Thread starter Bonzo94
Bonzo94
Hello everyone,
use 3ds max 2016. I've been learning to use it for a few days. I imported the model from autocad architecture and started working on it with 3ds. I have made evidence to render, etc. until now all of a sudden at the yet render, the result was this.
I don't really know how to explain it, and I need help from someone who understands something because I don't know where to put my hands.
thanks in advance
to the eye is a matter of the material, but I could safely wrong. if you change material, even any other than the applied one that happens?
I tried, but as you can see from the annex, I had no results. I used the concrete of the flooring, which to make seems perfect.
what I noticed is:
1. initially when I applied a material to an object, for example wall, 3ds gave the same material to all walls contained in all layers. one of the last operations I have done before the problem arises, it was, through edit poly and detach, to assign to walls of the ground floor a new material in the inner layer.
2. the render despite having a very low quality, as from settings, is slow.Cattura.webp
It would seem like a displacement problem. You know what it is?
to verify it enters the parameters of the material and scroll until you find the displace parameter, most likely you have entered too high value
Thank you very much.
are you fucking kidding me?? :Have:
and true, but for personal use, you can find a "free version. . "
Yeah? !...but think about you! tomorrow I want to try to ask my store of trust a new photographic equipment pro; since photography is just a hobby I see if I can make it "gratis", since it is "for personal use". What do you think, I'll make it?
find a vray, and a manual how to use it. and you won't have a problem.
the manual :biggrin: I have the guide of Czechoslovaks paid 100 euros but I had to take private lessons, follow online tutorials etc. unfortunately it is enough to lose some passage in order not to do anything anymore.
we're going a little off topic... if you want to talk about guides and manuals open a new tread
