a small help
  • Thread starter Thread starter ceschi1959
ceschi1959
excuse the intromission, what do you mean with upholstered hole in inventor?
Thanks for the answers, I hope to return.
c.
thank you all,
I believe you want threaded hole (tapped and not tapered).
Thanks again I owe you a beer! :-)
install the language pack, maybe solve some problems....
upholstered hole = pinned hole = blind hole
tapered hole = tapered hole = conical
these are the correct translations.
then maybe the best way to find out would be to apply the command..... just to understand well what happens, if you own the program.
reality in any way is another....
the options are 4:
here you can see the various options.
https://knowledge.autodesk.com/supp...13509cae-15e8-4f3e-b267-b32e5bfb45f4-htm.htmlThis video might help.https://www.youtube.com/watch?v=tlwf8sw8lqa
from left to right, the 4 icons in the hole window (version 2014)
- simple hole------------- simple hole
- clearance hole-------hole with game
- taped hole------------ threaded hole
- taper upholsterd hole----- threaded hole conical
