a window in the plant is represented
  • Thread starter Thread starter Giovannino60
Giovannino60
Hello, I ask in archicad 15 I executed a drawing:
1) because the object window in the plant appears drawn. I checked even if the position, in height, is on the cutting line of the plant but this is correct, cm 140, the design is in cm.
2) because I see in the plant on the first floor I see the door (defined normally) that is on the ground floor.
Thank you for your answers.
select only the wall and make a 3d view, to see if it is as it should, both "he" and its openings (quota, height, position)
I do not see any anomalies except the question of the dotted view of the window in the plant.
the wall I designed it unique i.e. I did not divide it on the ground floor for example m. 3 height and on the second floor for example m. 3 height. I don't know if this can cause problems.
Of course! one of the two windows will result outside the representation defined by the cutting plan of the plant and will be considered "projected" overlapping to the other. But why did you make a unique wall? did you do this for the whole project, or just for this particular wall?
