Giuseppe Beatrice
still a problem of blocks.
a .dwg file created by other program (sienergy pro, electrical design siemens) contains blocks, re-elaborable with autocad 2007, the least strange (I attach the file containing one of the blocks, named u_mt), for the following behaviors (for brevity I mention only a few)
1)Adjustments with export command accepted only to the attribute after q
1)change with bar ownership accepted only if I click on a single block
3)examined the block with the editor, the labels indicated do not coincide with those obtained from export
4) also note that the labels on the exported .txt file do not coincide, since the numbers are preceded by sign "-"
nb: if I explode the block and redefine a twin (mt_mio), the behavior of the latter returns normal (see block mt_my contained in the file).
