marcof
hi to all, I resumed swx (version 2013) intensively after a relatively jumpy period of use and for simple work.
I am making a single project starting from the modification of an old man of whom I made a pck and go renamed assemblies, parts drawings etc. one of the parts has about fifty configurations and each corresponds to a relative component in the axis. the suppression/reactivation of the various functions are controlled by a rather full data table. I noticed that at least a dozen features when they are suspended, but they have the active sketch, while for others the sketch is also suspended.
I come to the questions:
1- Do you know what depends on the fact that a feature is suspended but not its sketch?
2- since the regeneration of the assemblies when these parts are all loaded is not a joke you think that the 15x54 sketches solved but useless because fathers of the only feature suppressed, can negatively affect the recalculating times?
3- sketch names are the default ones (scratch 102, sketch 103 etc.) while faetures are renamed as needed. If I renounce now the schetch so that they are easily identifiable can happen some mess of lost references? I remember that they are sketches connected to the only feature above and obviously to the geometry of the component.
4- I would like to change the data table setting the deletion/activation of sketches instead of doing it by hand for each of the 54 configurations, obtaining among other things the advantage that suppressing the sketch I would automatically go to suppress not only its feature but also a feature daughter, thus halving the number of columns in the data table. You think that's a good idea?
I didn't write. I came back and came back from niubbo, besides with a post maybe not too clear!
and mò are caxxi yours (in the next message I will ask if you can save in a previous verse)
