add a parameter
  • Thread starter Thread starter Alessio85
Alessio85
Hello, everyone! !
I have a problem with catia v5r20 I don't think I understand how it works if I want to create a parameter with, for example, a length. I mean I would like to appear in the logical tree, in the submenù parameters, with the name I defined and that clicking on it opens the window to define the entity.
Does anyone explain how to handle the parameters? ?
Thank you very much. .
Hello, everyone! !
in tools\options\infrastructure\partinfrastucture table "visualize" active in " logical tree visualizations" activates the options "vicles, parameters and relationships.
to create a parameter seeks the button with the f(x) symbol at the bottom of the finaestra, choose the parameter type and create it with its button, after which you change the name and define the value.
Thank you very much for the answer,
But I wanted to ask you something else like I do to associate the parameter I created at a length quota that I have already defined in my model.
For example if I want to parameterize the diameter of a circle, I created a length parameter and gave it a name, then as I associate it to the diameter.... ?
can not associate parameters by function if the quota is of type diameter.
catia calculates its functions only on the rays, so if you define a length parameter, which for you is a diameter, you will first define the dimensional bond from diameter to radius, after which apply a formula of the type "tuo_parameter/2".
Hi, I'll join the discussion. . I want to tie a parameter to a quota, I expect to find the f(x) symbol inside the "definition of the bond" window but it is not present. How come? Is there any strange settings?
p.
use catiav5r20
to create a formula on the definition window of a parameter you have to make buttondx on the numerical field of the constraint definition window, the first entry of the pop-up menu will be "create formula".
