with add rototranslation to help you also find an exampleHi.
how do you extrude given a basic figure and following a 3d line ....how do you do??? ?
p.s. good year late
a curiosity: the generated solid is then "connected" somehow to the 3d curve, in the sense that changing the curve can also change the solid?with add rototranslation to help you also find an example
no slegatoa curiosity: the generated solid is then "connected" somehow to the 3d curve, in the sense that changing the curve can also change the solid?
