add row in abaco
  • Thread starter Thread starter 0Laura0
0Laura0
Hi guys... I have a lot of practice with the forums, I tried to find the subject but I found it. .spero nn is 1 "double". .
I have 1 row of revit with 1 abaco already inserted that I didn't do...I wanted to know how to add 1 row because it is not clear at all.
thanks to all =)
In principle, the abbot lists families and/or elements contained in families (parameters).
For example, if you call the wall abacus, list all walls.
if you ask "to insert a line" (to the wall abacus) is to draw a new family/type wall in the project.
clarify your request better
Uh...no, it's not my case...(I'm sorry but I'm struggling to explain it because the abacus I have in the project didn't do it myself)..I give you 1 example..I have the abacus of the areas x the calculation of the sul..How do I add 1 area (so 1 new line) in the abacus if on 6 that are designed me only 1?
I hope to have been 1 fur + clear.. I doubt it. :confused: )
not so much...in the sense that the abacus is not a static table but a view to all effects. If you see only a record is because there is only one area (the area is then vague... local areas? )
... it is possible that the abacus is set to order/aggregate data compared to a parameter ...
