add sheets .frm
  • Thread starter Thread starter vincap85
vincap85
Good morning to all,
I am new here, and I do the accomplishments for this forum, very interesting. I wanted to have my "problem"
can you add more than two sheets within the .frm file format?
then how can I do to make the edges of a table in which a string is inserted, white and export the file to pdf so that those edges do not appear black?? ? . ....I hope I've explained well....thank you who will answer me
that I know the .frm is limited to 2 sheets
I don't understand how you want the edges to be found in pdf...
hi, as the good nicksoft says the limit for what I know too, is 2 sheets for formats, if you have needs of a certain type, you can solve by making you a specific template.
for the table, if you are doing the cartilage, you can join the cells or delete from the view the edges, the cell however remains bound.
are all table options.
