add tolerances
  • Thread starter Thread starter doriano
doriano
Good morning
I would like to know if it is possible to add tolerances beyond those standards.
I'll explain better. When I go to quote a drawing drawing design and I have to put catia tolerances v5r20 proposes to me those standards, here I would like to add others so I do not always have to change them.
thanks to all
If I'm not mistaken you can do in xml files. Sorry the answer a little vague but I don't remember the details
is correct......... you can do in the standards.
It seems to me already explained somewhere......
you have to start caia in administrator mode (in the forum is explained how to do) .............
then in tools/standard open the standard file
select the type of file drafting and the name of the file you use when drawings (I suggest you create one with a name you want and then change it, you will see that in addition to the tolerances you can make a tide of changes) then go on general/tolerance values/number tolerance values and here you put the tolerances you want and use + frequently which will then be displayed default in the list of tolerances.
Thanks for the answer, but where do I find the topic in the forum?
