added variable the logical roule
  • Thread starter Thread starter silvia_cherry
silvia_cherry
Hello, everyone!
I have this ilogic rule that exports me the dxf of the various plates inside a set in inventor
'define the active document as an assembly filedim oasmdoc as assemblydocument
oasmdoc = thisapplication.asset
oasmname = left(oasmdoc.displayname, len(oasmdoc.displayname) -4)
'check that the active document is an assembly fileif thisapplication.activedocument.documenttype <> kassemblydocumentobject then
messagebox.show("please run this rule from the assembly file.", "ilogic")
exit sub
end if
'get user inputwear and tear = messagebox.show ( _
"this will create a dxf file for all of the asembly components that are sheet metal." _&gt; vblf &gt; "this rule expects that the part file is saved." _&gt; vblf &gt; " " _&gt; vblf &gt; "are you sure you want to create dxf for all of the assembly components?" _&gt; vblf &gt; "this could take a while.", "ilogic - batch output dxfs ",messageboxbuttons.yesno)
if wear and tear = vto then
return
else
end if
opath = thisdoc.pathodatamedium = thisapplication.transientobjects.createdatamedium
ocontext = thisapplication.transientobjects.createtranslationcontext
ocontext.type = iomechanismenum.kfilebrowseiomechanism
ooptions = thisapplication.transientobjects.createnamevaluemap
'get dxf target folds pathOfolder = opath &gt; "\" &gt; oasmname &gt; "dxf files"
'check for the dxf folder and create it if it does not existif not system.io.directory.exists(Ofolder) then
system.io.directory.createdirectory(Ofolder)
end if'- - - - - - - - - - - - -
'- - - - - - - - - - - - -component - - - - - - - - - - - -
'look at the files referenced by the assembly
dim orefdocs as documentsenumerator
Orefdocs = oasmdoc.allreferenceddocuments
dim orefdoc as document
'work the the drawing files for the referenced models
'this expects that the model has been saved
for each orefdoc in orefdocs
iptpathname = left(orefdoc.fulldocumentame, len(orefdoc. fulldocument) - 3) &gt; Ipt.
'check that model is saved(system- Me.exists(Pitpathname)) then
dim odrawdoc as partdocument
odrawdoc = thisapplicationDocuments.open(iptpathname, true)
ofilename = left(orefdoc.displayname, len(orefdoc.displayname))
try
'set the dxf target file nameodatamedium.filename = Ofolder &gt; "\" &gt; ofilename &gt; ".dxf"
dim ocompdef as sheetmetalcomponentdefinition
ocompdef = odrawdoc.componentdefinition
if ocompdef.hasflatpattern = false thenocompdef.unfold
else
ocompdef.flatpattern.edit
end if
dim aid as stringaid = "flat pattern dxf?acadversion=2004" _+
"&outerprofilelayer=iv_outer_profile" _+
"&interioprofileslayer=iv_interior_profiles" _+
"&invisiblelayers=iv_tangent;iv_bend;iv_bend_down;iv_bend_up;iv_arc_centers;iv_tool_center;iv_tool_center_down;iv_feature_profiles;iv_feature_profiles_down;iv_altrep_front;iv_altrep_back;iv_unconsumed_sketches;iv_roll_tangent;iv_roll"
ocompdef.dataio.writedatatofile( sout, odatamedium.filename)
'just for check its works coretcly
'i=messagebox.show(odatamedium.filename, "title",messageboxbuttons.okcancel)
'messagebox.show(i,"title",messageboxbuttons.ok)
'if i=2 then
'exit sub
'end if
ocompdef.flatpattern.exitedit
catch
end try
odrawdoc.close
else
end if
nextthe rule works very well, it exports me all the plates but I do not want me to export them all (some of them the customer already has them in stock so you do not have to order them that is why I do the dxf that will then be sent to the supplier) to distinguish the plates to order from those we have not inserted the property 'pannello' in the field 'supplier' in the menu iproperties. I've seen you call back this way
param=iproperties.value("project", "vendor")
the thing I can't do is add to the rule the fact that if the field supplier is empty you don't make me the dxf, if it presents the word 'pannello' you create the dxf.
Thank you very much
hi, be careful with ilogic shortcuts, the access you show is to the active document, for example if you need access to the property of a display template file, you should perform another access method.
This is why I ask you, where is the property "vendor"? in the display pattern file found on the sheet?
@sergio.d.suarez the "vendor" popility corresponds to the 'supplier' that is located between the iproperties of the 3d model, but I don't think that's the answer to your question
un metodo più sicuro per accedere alle proprietà dei documenti è quello che ti mostro di seguito.
devi specificare il documento in cui si trova la proprietà di cui hai bisogno. penso che dovresti presentare questo approccio nella tua regola.
dim odoc as document = thisdoc.document
dim ovendor as string = odoc.propertysets.item("design tracking properties").item("vendor").value
ora, per adattare la tua regola, penso che dovresti trovare qualcosa di simile al seguente
oasmdoc = thisapplication.activedocument
exit sub
end if
'get user input
rusure = messagebox.show ( _
& vblf & "this rule expects that the part file is saved." _
& vblf & " " _
& vblf & "are you sure you want to create dxf for all of the assembly components?" _
& vblf & "this could take a while.", "ilogic - batch output dxfs ",messageboxbuttons.yesno)
if rusure = vbno then
return
else
end if
'get dxf target folder path
ofolder = opath & "\" & oasmname & " dxf files"
if not system.io.directory.exists(ofolder) then
system.io.directory.createdirectory(ofolder)
end if
for each orefdoc as document in oasmdoc.allreferenceddocuments
topdor = orefdoc.propertysets.item("design tracking properties).item("vendor).value if ovendor = "pannello" then
iptpathname = left(orefdoc.fulldocumentname, len(orefdoc.fulldocumentname) - 3) & "ipt"
if(system.io.file.exists(iptpathname)) then
odrawdoc = thisapplication.documents.open(iptpathname, true)
try
odatamedium.filename = ofolder & "\" & ofilename & ".dxf"
ocompdef.unfold
else
end if
dim sout as string
sout = "flat pattern dxf?acadversion=2004" _
'if i=2 then
'exit sub
'end if
catch
end try
odrawdoc.close
end if end ifnext
I highlighted the lines I added in red.
by this method you will look for the value of the "supplier" property of each file of parts and if this property is equal to "panel", it will be converted to dxf when you need it. (if you need the opposite simply replace = with signs <> to create the "different")
I also carried out a reorganization, through the "tab" button, this to make the code more readable and easy to understand at first sight. if it is not reorganized, it is not known at first sight where it begins and ends a specific instruction.
I hope the code's contribution is clear. you can consult this information for more details about access to properties, it is the vba language, but it can be easily adapted to the ilogical.
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html I hope something here can help you.
Goodbye
Excuse me, I'm new in the forum and I could verify that here you can't make corrections with the tab key, when entering the spaces are deleted. greetings
Thank you so much! I'll try and let you know tomorrow. Thanks again, very kind!
