adjustable underarms
  • Thread starter Thread starter power23
power23
Hello, guys.
I will ask a question for you... but much less for me than I am at first.
We put that I have a subaxieme that has adjustments inside it...type with sunshades etc.
this subaxieme is mounted in multiple axiemi fathers...but maybe in each one its regulation is different.
how can I untie his regulation (inside the assieme father) compared to the subaxieme?
in practice if I do the subaxieme regulation in the assieme father to...how do I not change his assembly in the assieme father b...c...d...ecc.
I'm sure I'm gonna have to work with the restraints...maybe within the axial fathers...and not the sub-assistance. . .
Can I help you?
What do you mean by "regulation"?
first-attention would be to say that you have to use the family tables for the components and for the assemblies.
uses flexibility, allows you to create variable configurations within your sub-axis according to odds, parameters, etc.
This prevents you from managing everything with your family tables, so create variants of subvariants.
hello and thanks for the answers.
I make a mini example.
in a subaxieme I have plate to and plate b flowing between them by means of asole.
I put the subaxieme in multiple assiemi father...but in each of them the plate a and b of the subaxieme can be placed differently between them...so I have to adjust them in a set without changing their position in other assemblies.
if you can give me information about the procedure/commands.
Thanks
Yes I understand the problem, it is very clear to me, but my question is:
do you always want to maintain fixed positions in terms of altitude for these movements? if yes, then you are forced to use the family, you create a family table only for the subaxieme of the 2 plates where as a variable share insert the minimum and maximum run that must have and possibly others, or with the flexibility but provided that the 2 plates are not in a subaxieme.
Would you like to get something like that?
Look at the model tree, take a look at the names...
perfect parametric_ozzy. Just what you did.
do you recommend me the most practical way to do so?
Thanks
in your subassieme create a real number parameter called for example race.
then create the relationship that manages the offset between the 2 plates example:
d2=corsa
in the main axieme, dx button on the bottom together and selections make flexible.
at this point go to the parameters tab and select the run parameter and change the values in the various sub-axis.
doing so the positioning will always be dependent on the main axieme and the subassiemi can have x racing.
I hope I've been clear
ps: what version do you use?
Thank you very much... I use the wf5 in the company... and we say I'm starting to family. . .
still misses a lot.. I'm shaping myself, but it's still long.
of the 2d we do not talk about it...0 total yet.
I try your method... if I have problems I will break you again....sorry.
Ozzy, I'm really kissed.
explain to me a little more in detail the various steps/passes you have to do?
I'm sorry, but I'm just a rookie.
Thanks
Okay, I managed to recreate something like ozzy.
If, however, in the main axieme, I have to change the variable (the race in the example of ozzy)... dx button on the subassieme-modifies parameters...and I insert a new vapor. (laughing) )
but magically it changes my race on the first subaxieme...and not on the second on which I clicked with the dx.
Why?
Why?
I'm sorry, but I don't have much time. I'm gonna give you the example I did.
each subset is "flexible" with the race that you impute in the parameter value flexibility only for that subassieme.View attachment flessibilita.rar
all clear ozzy with your example and your files.
last small step... in the main axieme I gave a x value to the race quota (d2) making the subaxieme flexible.
if then however I want to correct and then change the value inserted for the race....what operation should I do?
Thanks
