advance steel 2012
  • Thread starter Thread starter sahachiel
sahachiel
hello to all
Is there anyone using the software in question?
I am at the very first weapons and I would need a little help:redface:, I should draw a single-faced iron shed and I can't.. .
thanks in advance
Giuseppe
I moved the discussion to the correct forum. . .
some indication is given in previous discussions: use the function "research in the forum ..."
Good evening.
Thanks for moving the topic, I did a search before posting, but they all talk about the software and not how to use it:)
thanks in advance
Giuseppe
with such a request I doubt you can find answers. It's like I said, "I bought a car with automatic transmission but I can't drive it, how do I? "
Hey, did you take the course? Have you read the manuals?
However if you have the starting guide there are explained the various steps: modeling, marking, distinct, put on the table..poi you find various videos on youtube that can be of help. .
Perhaps if you have some doubt about something in particular (that I know.. how to model a knot on your knee, or how do I get the distinct etc.) it is easier for those who use it to answer you!:confused:
Anyway, good luck with your project!
simone
I read only now the discussion, I am seeing it as self-taught and some way I can shape
to realize your shed you can also start using but dedicated matrix, as modeling> structural elements> timpane portal and use joints, beam column> joint bolted with reinforcement to create joint between the column and the beam of the ground, joint beam beam > joint with reinforcement
