advance steel blade bar 2012
  • Thread starter Thread starter doking
doking
I don't know where to post since there is no dedicated section:confused:
I can't show the advance steel palette bar 2012, i.e. I can activate the autocad palette bar but I don't see the advance steel tables, you know how to reactivate them?
Hello docking,
Yes, but for precaution do these steps.
go to autocad options in the first file card, support file. remove all strings where you read graitec. restart advance and charge the palettes.
Bye.
hi, I had in advance test, but in standalone version.
in the top bar, where there is written home,objects,extended pattern....click on view.
on the quick access bar that opened click now on "sheets".
I don't know if that's the answer you're looking for, I hope I've been helpful.
Hello docking,
Bye.
hi studiodl solved already like this:finger:
Hi, I'll be there.
sometimes only a few palettes disappear. ..it should close, open autocad alone, in the personalization card, interface do reread the aad.ciux.poi you start the advance and it is ok.
I hope you're useful.
Hi, I'll be there.
Hello simonetta,
I spoke a few days ago with the assistance, also manifesting these problems.
I was told that they are the source of autocad palettes to be unstable and, knowing the problem, they created own tables of advance.
They gave me this link, see if it can help you.http://www.graitec.info/common/downloads/documentation/as2013_whats_new_en.pdf ciao.
