doking
for those who are practical of advance steel, I noticed that creating a folded dish I have way to manage flat justification, I imagine it is the yielding of the sheet during the fold, a sort of factor k that is found in solidworks
in advance steel I noticed that varying the justifying value modifies the dish instantly and not as I imagined in development, I explain better, if I create an elle-shaped sheet having 100mm to the vertical sheet and 100mm to the vertical sheet, imposed the vertical sheet as the main element, after creating the fold, I change the justifying value from 0 that is the value set to 0.5 known that the vertical sheet shortens of 5mm
I ask myself: but should not the length of the folded sheets remain unchanged and should the length in the development phase change?
that some changes to be made in manager or am I wrong somehow?
