advice for window views
jim78b
I have to draw in 3d, but I find it bad to place the views, I would like a council to work in 3d and one for 2d, you put the 2 vertical views, but I think the screen is too small! I look for a way to see the best and faster work I do thanks,
ps ho autocad 2008
I'm sorry if I tell you, but I find this useless post. do some tests and see which interface you find best.
It's a little hard to advise you, as Tristan said, you have to do some tests and see. each has its own working method and then mainly depends on the type of monitor you use.
Jimmy,
If the space on the screen is limited, I suggest you evaluate the use of the double monitor: attached my office location.
Hello
I was looking for a singleution to my problem about using the double monitor:
I intend to view, of the same 3d file, on a monitor a view in the plant (for example) and on the other monitor a prospect.
Thank you and I apologize for ignorance.
Hello
you need to use the screen extension mode in the graphics card drivers.
This presupposes that the two monitors are equal (same resolution).
and then you split the autocad work area into two windows.
Thank you very much I assumed right, unfortunately the duies nno screens are equal
