pulce1988
Good morning to all, I recently found this forum (I made the presentation in the special section...), and I open this post to ask you a advice to model an aspiration horn for thermal motor as from photo. I thought of a blend of sweep, but the problem that the back of the croup should remain orthogonal at the base, while the opposite side should start bending. I also thought of a limit blend but I'm afraid to further complicate things....you mean how would you?
Leaving to lose that I made the blend line of sweep straight, I also have the problem that in the configuration of the sweep blend when I put it creates a surface instead of creating solid, giving ok I do not find the feature in sight to the contrary of when I put solid creation...thanks for the time devoted to me.. .
