advice
  • Thread starter Thread starter AC Design
AC Design
Good morning to all... and as usual welcome!
I would have a question to ask you.
I should give movement to the surface I attach. I'll explain.
The surface is the base of a linear extrusion of a twin but higher surface. we say like a low relief. So what you see is the engraving floor.
I would like to move to this floor so as not to make it look too straight...with different heights and maybe with bombings down...how can I do?
I know that with t-spline it's boys' stuff, but not having external plug-ins what can I make up for you?
I had thought about creating internal curves and making all networks, but it's so bad. . .
thanks in advance,
alessandro.
thanks in advance,
alessandro.
I have just begun to use t-spline even if I have to take hand for good and in fact this system seems quite comfortable, with the classic method perhaps a solution could be the points of control even if it is a little long and dummy work.
In fact, the problem is exactly that... the very little time I have... with t splens how could I do it? is it possible, in a short time, to arrive at an acceptable result? My partner has an old version. Can't tell me which one, it looks like the two of you with which version you work with?
ale
ale
look for t-spline I can tell you little I am still at the beginning I downloaded a guide and tutorials even if in English and piano I army but from what little I have seen you can create some "scacchi" on the surfaces and model them one by one or more of one together then a system decidedly comfortable, too I have an old version I think the 2.
