N5L
Hello everyone, I'm struggling with one of my first modeling in part environment and I wanted to ask you a question. I press that I have used the search function but I have not found answer to my problem. I am modeling an ignition candle as one rigid body and I was trying to make a m14*1,25 aesthetic thread. Designed the propeller with its step and designed the simple triangular profile bound, I finally used the feature groove. It presents itself with sweep error, loft or connection... and the excavation that does not resemble a true thread at all. I tried various profiles and the only one that doesn't bother me is circumference but I would like to use the triangle to stick to the real. I await your answer or suggestion, thank you all.
