biz
Good morning.
you also often happen that by changing a subgroup (for example), then removing/adjusting components the design in the annotation environment does not update? In particular, if you have to change a drawing part (shaft, carpentry, etc.) this part is updated, while if you have to add a component to trade (vite, seeger, etc.) this does not appear on the table. I use the 18.0
