aid mechanism
  • Thread starter Thread starter fratello
fratello
I try to put it here....
Hello everyone
You would help me realize this mechanism.
I quickly made parts to simulate the concept....in practice the piston pushes the rebound that rises by turning on fixed pins.
In practice I would like to give a rotation joint to the rebound and make the piston rod go after it.
I thought I could do it easily but I'm definitely doing something wrong.
help
You made only a small mistake.
or you used a cylindrical joint instead of the rotation joint.
therefore the cad still has a degree of freedom.
I am talking about the joint number 2 of the tree (the second in list).
replace it with a rotation joint.
in other words the piston may be rotated around the pin but also move along the direction of the axis of the pin itself ( precisely cylindrical joint).
from the gods with an offset and you are affixed.
many words but you will easily find out. Say hi.
