alignment command line text.
  • Thread starter Thread starter edg76
edg76
Hello everyone.. .
for a while, I don't know why but the result command line texts moved to the right of the same as from attached images. I uninstalled autocad 2021 and installed the 2022 but the problem persists and only on this pc... Does anyone have a solution to restore the text position in the command line rows?Senza titolo-1.webpSenza titolo-2.webp
It's like autocad set the window according to the space that is allowed by the screen resolution. the position of that window in fact is not adjustable in any way through the options of autocad. it is possible only to move it with the mouse, but in any case the window always opens with justification on the left. so it depends on the screen resolution. try setting resolution with higher values like 1920 x1080
