alloy circle
  • Thread starter Thread starter Ing.Martin
Ing.Martin
Hi, by my dialect I drew a alloy circle.
I chose as size 20" therefore as a calettament diameter I calculated 20*25.4=508 mm and as width 290 mm.
designed the circle I set the aluminum material and calculated the mass, only that I get about 100 kg!!! ! !
Where did I go wrong? I can't find the mistake I made.
I found the mistake. Let's say I had made a 40-inch alloy circle." I have to learn to think a little more....
These are things that happen when you don't have a global project reference... If you were next to the suspension, you'd have noticed.
a sorrow, when you have to do with conversions of the units of measurement you can edit the quota of the bond followed by the descriptive of the unit of measurement.
Having the metric configuration, you can enter the value of the bond quota, you just split to "20 in" examples, the system is calculated conversion.
