alternative to configurations
  • Thread starter Thread starter Gach74
test
interesting but not my case, too much information lost or not interceptable.
parts in parts are not exactly the function I appreciate more than the software
anyway thanks for giving me a different viewpoint to be able to evaluate
test
I understand that losing the definition of features you have the feeling of not having control of the part anymore, but the potential is not negligible.
Thanks anyway for letting me participate! :
edit: I realized now that my solution was the same date from @massivonweizen
I don't question it....
but the message I try to pass is that it is the control of the historian of these parts the only thing I care about at the end not so much the technique of modeling
the control of the functions I do not care because they are managed from the source part
I realized that your problem has nothing to do with configurations and possible alternatives, but it falls within the management of the versions.
Premitting that I continue to understand little of all this management, I attach an example of how I mean management, which may not be what you need, with a master and parts attached to it.
in the annex you will find the master called part1 in which I created 4 configurations.
then you will find 3 end conf1, conf2, conf3 that are obtained by creating a derivative part (right button on the body in the cut-off list > insert in the new part) that I referred to a specific configuration that, although not having the historical of the functions, remains always bound to his master and will undergo the changes if the latter vien modified.
Finally you will find additional 2 conf1-a and conf1-b files that are nothing but copies of conf1 to which I added functions. of this configured part I can save n thousand variants to which to make as many changes as I want and in case I change the configuration in the master file these verreberal modifications propagated to all conf1-xxxxx files. if then for a specific variant you didn't want the above changes to be propagated just right-click on the first context function?
  • conf1 -B.zip
    conf1 -B.zip
After a first analysis I can say that it's not what I'm looking for.. but your example lit me several bulbs for different uses than we're talking about.
here management is so varied and complicated that everything sooner or later comes good.
in case I will let you know in a new post for what I used your example-
thanks for the time you have dedicated to me.
