aluminium container design hammond
  • Thread starter Thread starter cirillo87
cirillo87
Hello everyone,I have to design an aluminum container of the hammond series 1590,ip54,screened,black,187.5*119.5*78mm on nsolidworks 2017.adesso I send you photos with the datasheet!175.webp176.webp
when I make the container,excluding the lid,I have a gap between the top part and the bottom part of 3mm because above the container is 188*120mm and below is 182*114mm,how do you do the flushing?
I think it's the extraction sform. . I think. .
and do not flood the forum with the same message in the various sections. . .
So when I go into the deformed function... there should be disformed by extraction, imagine!
but do you know how to use the program or are you randomly pulling hopes for some way to catch us?
instead of describing, word I use with wide margin, your problem, attach the file that anyone can try to understand what you have done there what needs to be settled.
