aluminium container design
  • Thread starter Thread starter cirillo87
cirillo87
Hello everyone,I have to design an aluminum container hammond series 1590,ip54,black screened,187.5*119.5*78mm on solidworks2017,any could give me a hand?
at least 4 discussions with the same request, it is not that more requests do more answers get
the answer, in addition to not posting several times is to do with the sheet module and then to make the seals and to assimilate everything.
But you have problems that you can't shape, don't you understand the design? If you don't explain, it's hard to know what to explain.
That thing, which looks like a normal tin box from industrial electrical installations has the case and the lid. maybe a seal mounted on the case. are commetchual things that zanardo or other manufacturers also have 3d models downloadable.
If you feel that it is made of die casting and not of bent sheet....you have to justify the thing.
exact is a normal cassette for electrical installations, only that the professor gave me to draw this cassette and I never used solidworks, it's all new to me!
then do the internal tutorials to the program and then start describing the problem with knowledge of cause
the next identical discussion opened by cirillo87 will be reported in the moderator area.
