maxopus
Good morning.
I was commissioned by a customer to make a new product.
This is an electronic pen for the aesthetic sector.
I attach an image to make you understand a lot of what this is about.
I have defined all dimensional and functional specifications and now I want to make a proposal on surface aesthetic finish.
As a rule these objects are made of aluminum for reasons of lightness and heat dissipation (inside there is a micromotor at 6-7,000 rpm).
I think that in order to have a good aesthetic finish you have to proceed with a mechanical processing with 1,6 roughness and therefore with an anodic oxidation that can be neutral or colored.
I wanted to ask if you happen to know companies that carry out such processes or if, for example, you know companies that make a lacquer of excellent quality on metal minuteries.
the problem is the resistance of the finish, we talk about professional objects subject to a very intense use, so the finish must last years.
I know some companies in the area that make anodic oxidation but, they do not work on minuteries with specifications of high aesthetic quality.
Do you realize that you want to finish the barrel of a montblanc... what process would you adopt?
Thank you in advance.
