Colaexperienced
I am a student of aeronautical engineering and I am designing a steering box for a racing car.
since the forces at stake are relatively small (the axial forces in the steering arms reach up to 1000 n), I thought of making the teeth of the pinion and the rack in alloy
of aluminium 7075 t6 (sy=505 mpa hb=160).
for bending resistance there are no problems.
with regard to wear resistance (which is probably the most restrictive requirement for aluminium) instead I found no usable data.
I would therefore need data relating to aluminum alloys to be able to measure with sufficient accuracy the teeth of the surface fatigue steering.
