Filo Guest Mar 8, 2012 #1 I would like to do an analysis of 2 plates connected with bolts, what are the best constraints to use to simulate this situation? Hi. Thank you.
cassero88 Guest Apr 4, 2012 #2 the constraint with the coincidence with regards to the rotation axes and then do the analysis properly putting the forces and use the fixing between the two holes with the grip command (it seems to be called so ) in order to simulate the bolt
