riccardot5765
I searched in the different threads but I didn't find what I need.
Therefore, for me, the problem is as follows:
I have a defined diameter and thickness tube, at which a particular esothermic reaction occurs and I want to adjust the output temperature by means of a series of windings. at this point I insert all the data in mathcad i find the total length of the ''tubo'', reaction temperature and, fix the output one, the heat exchange to realize, and therefore the ''length of the serpentine''. Obviously these parameters will vary depending on the flow rate and the reaction you have.
My question is: is it possible to make sure that in proe can use the data that come out of me from mathcad? on the net I found nothing, only a video on youtube that modified the height of a parallelepiped by external analysis with mathcad. Can someone give me a tip?
