analysis thickness
TECNOMODEL
I have long been searching for a method of analyzing the thickness of a part to determine whether there were difformities, too thin thicknesses etc.
to today I found nothing, possible that not even in 2016 autodesk thought of a command that would be not only useful but fundamental?
interesting, but I do not have metal parts but metal castings.
I would like to verify in a simple and accurate way the thickness of the artifact.
In particular, I should check that there are no areas with a thickness less than a certain value.
on solidworks there is a command that does this analysis, I am looking for something similar in inventor but unnecessarily.
in inventor analysis tools is what you are looking for:
"cross-section analysis" is the last
with cross-section analysis is a delirium.
I should do n thousand sections 0.5 mm away to be accurate.
this is in x and y.
after moving in what jumps out is a nightmare.
tried with 5 mm distance sections and already is unmanageable.
thank you for the link cast16, I have already seen it.I contacted the creator, I am waiting for his answer because he is evaluating how to "customize him" for our needs.
If the cost is accessible I think it is a shopping to do without thinking twice.
I knew a software that did it, but just passing through a stl export, a little laborious. . .
(in case, it's called "netfabb")
I can't understand from the site if in the basic version there is the function that interests me.
buy such software and use it only occasionally to verify thicknesses seems excessive
