analyzes sketch nel 3d
  • Thread starter Thread starter pianta
pianta
Good morning to all,
as from title my colleague created a sketch and would need to display it in the axieme where he created it (we noticed that the same happens in the parts).
The sketch can't be seen if you don't select it.
clikkando with the right there is no unhide option, but that hide :confused:
the level to which the sketch belongs is not "hide"
Doesn't anyone know?
Is that a question too easy?
has already been explained in other topics that I do not find?
I don't understand, would you like to see all the sketches of all the features? Of course you see what you select. or try to explain yourself better. . .
I want to see one
one in particular
that I need while I add other elements to the axieme.
Is that impossible?
I would try so
because maybe the sketch you did is contained in a feature that then incorporates it and hides it is enough to create a new sketch using the command " entity from the edge" , in this way you recalc the sketch that interests you and keeps it parametric
(or first create the sketch and then do the feature by focusing on the sketch)
in the 3d if it stays outside the solid you will see if it remains inserted in the material you will see only removing the shade
is not embedded in the feature, it is a sketch made using the sketch button.
It's not even in one part, I did it in the axieme.
is outside the material.
and you can't see.
and you can't see.
I tried with my design and it works.
have you tried to see if it is contained in some level that is hidden?
There are functions of the config pro that charge in various levels automatically various things
as I said in the first post is not in a hidden level.
I guess it's something in the config.pro, but I don't know what.
looking sketch comes out stuff but I don't think there's a lot
I found the answer, I leave you here for completeness
view-->display settings-->model display---> tab shade flaggare "with datum curves"
at this point you see sketches out of features and out of material.
