3DBix
I should create a dynamic block that as a form part of that attachment... is for a camera.
1. I should set the angle between the two lines of the angle of view. max 180°
2. I should set the radius of the arc so that the 2 lines will flood according to it.
3. I should set the angle of dx or sx to change the target point. (also only one of 2)
all this without geometry deforming, so it must always be a clove with an arc but of parametric dimensions.
I have tried in various ways but without success.... I imagine you should use the constraints that I can not use.
alternatively if someone could explain to me the logic of parameters-actions-wine to use at least I learn once and for all.
thanks for the help
bixView attachment BLKtest.dwg
thanks for the help
