animated path rendered - walkthrought
  • Thread starter Thread starter katy98
katy98
Hello, guys! !
I have a problem and I hope to solve it. . .can create a 3d animated path that allows me to walk inside a building in a photorealistic way? I may have mistaken some setting because at the moment I click on "animation" and insert the path as much as I can hope to see is a "wireframe" path....I hope to be properly explained! !
ps: I use revit architecture 2009.. .
once you create the animation percose, go to file>export>animation and choose rendering from graphic style format. The frames of the video will appear on the top right of the 2009 version. removed from 2010
I thank you for the suggestion... but I tried the video that I visualize is not fluid but goes to snaps....I believe it is a problem of setting frames and seconds between one frame and the other.. .
It seems to me that to have a smooth video..you need to utlize at least 25 frames per second. .
