animation assembly pieces 3d
  • Thread starter Thread starter fly71
fly71
hello to all, I wanted to ask if it is possible to make a simple assembly animation of mechanical pieces in 3d, I have a product designed in 3d and I want to show the phases of assembly of its pieces that make up it.
if you can do it you can tell me which guide or tutorial, use autocad 2007 or 2010
Greeting him
but is it not possible even with a sequence of shots a bit like a sequence of frames?
Maybe that programs I recommend to do something like that
How many pieces should you animate? If it's five, you can even think about it... if they are 50, better invent other methods
I could not quantify, when the pieces are plumbing, taps and niples, and each piece is formed in a simplified manner with cylinders and solids, for example bolts to mount the cover.
therefore it would be that each piece to move and formed by one or more solids.
as said by tristan autocad does not have this possibility.
As you say, you could handle the stop motion. But consider that you should put at least 4, 8 frames per second.
every frame will be a render. then a 1 minute video implies 300 renders all to manage by moving the pieces by hand after which you should mount the video.
:36_1_10:
