bonf2
hi guys, I have some issues with the export of animations with revit lt 2015.
I create the camera path, set the size in mm of the frame holding a ratio 16:9 but sometimes it gives me problems.. .
I have tried many variants, total frames number, second frames, pixel size video but I have not yet found where the problem is, which factor tilts the file; revit the video file creates it but it gives me error when I try to read it.
do as uniform color output settings, uncompressed frames, 1280x720 size, 20/30 frames second, total frames I tried everything, from 300 to 1200. .
If you have any settings to recommend, I wouldn't mind.
Thank you!
Thank you!
