ansys ds e il read only non funziona
  • Thread starter Thread starter gerod
gerod
up to v13 you could use ansys design space in read only if you were out of business and therefore without the license server.
cabbage, I am from the customer and I start wb 14 but not structural to see the results.
Is this hanging?
"part of wb 14 but not structural to see the results. "
It is not clear better explained.
simple.
In the office we have the license server that manages the ansys license.
If I'm not in the office, I can't use ansys (of course) but I can use it in read alone. In practice, I open a simulation and I look at it.
This, until 13:00 it worked. with 13 open the wb that warned you that you were in read only and then opened the mechanic.
with the 14 opens wb but then, at the opening of the simulation file, tells me that there is no license and that does not open it to me. therefore, read only does not work.
Did I explain?
crystalline ... and as such I answer ..
options->mechanical->pre-load the mechanical editor (remove the flag)
soon;)
Wow, that's what I feel!
boys, among other things the option "preload mechanical editor" can also create other problems much more serious.
if you do not have the service pack installed, and if this option is enabled by default, it is not disabled, it can happen that project files workbench are corrupted. to me it happened four or five times, and then I came to the head.
in practice this roman happened when I saved and immediately after I closed workbench; at the reopening... error!
then disable absolutely! ! !
There he is!
in fact I had to remake many simulations!
cabbage, of course, for a software that "it's not that it costs little" to have a setting that sends you to the air hours and hours of work .... I'd put it in mind to those who realize it (take the vent).
I told you qui.
I had solved by saying "no" when he asked some absurd questions.
thanks to eih64 for the straight.
