AndreaNSR125
Good morning to all, I must realize very long bushings and especially that they are economic, with a somewhat particular technique.
in practice I have of the classic round rectified from 16,00mm, on which I made a quarry of 3mm width and 6mm depth for anchoring (in practice I made a supported tree).
on this tree I have to run a bushing as long as the tree (200mm) with the least possible tolerance and of course with the least possible friction.
everything is necessary to move now a cross table and in the future a cnc machine.
the bushing is currently made in this way: I sprinkle the tree with epoxy resin strongly loaded with bronze powder (which I always get) and then wrap it in multiple layers of carbon fiber (to have structural stiffness).
At the moment I find myself having a not very low friction coefficient, and especially when I extract the laminate, it has a diameter of a few cents lower than the 16,00 of the tree, I think because of the thickness of the loaded resin layer that causes this deformation in the polymerization phase.
this precarious in reality would not be so bad (it contributes to stiffness altogether, for a more precise handling), the problem is that then the tree remains well tightened inside the bushing and to move it needs a lot of strength.
I therefore wanted to replace the layer of charged resin, with a thin sheet of non-stick material, which therefore still manages to take the precise shape of the piece, but with a much better friction coefficient. . .
What can I use?
I natually thought of a sheet of bronze or teflon, but with the bronze I don't know how much they can find thin sheets in a low friction alloy, while for the teflon I have some doubt about the duration and actual friction coefficient (I took the classic teflon tape to seal the threads, and flowed on the metal is not that it was very slippery. . . )
What can I use?
