volaff
Hey, everybody.
after many vicissitudes I corrected the panel model that contains the hp.
I removed the constraints and loads and then corrected geometry by remeshating the various areas affected by the change.
When, though, I go to do static analysis, the message appears to me:
"" a small equation solver pivot term has been encountered at the uy
degree of freedom of node 38941. ansys has automatically constrained
This degree of freedom. check for an insufficiently constrained
model.
if I solve in scattered mode, a similar error if I solve pcg.
as they suggested this error could be due to parts of the model not properly bound for which they urged me to carry out a modal analysis to verify the possible presence of part of the rigid body not bound.
I point out that in my model it was not defined the density for which I inserted a similar to that of steel.
I realized the modal analysis with the following options:
sopt: block lanczos
No. od modes to extract:10
no. of modes to expand: 10
it's been three hours and the analysis is less than half, at cycle number 6.
My pc has 6 gb of ram.
I was wondering if the procedure was correct even in relation to the times.
Thank you all.
I have done this
model.
sopt: block lanczos
Thank you all.
I have done this
