aperture tabs create con wf5
  • Thread starter Thread starter peppino_inglese
peppino_inglese
Hello, everyone. even if I have already presented myself in the right section, I repeat, beppe 23 from the commission of bari.
as you will have noticed from the title of the post I would need some delucidations/suggestions.
a few weeks ago I installed a "demo" of proe wf5 with which I worked for these 15 days, only flaw, I didn't really like the graphical interface, and as I had (and I) need to complete the job, I didn't change settings, I simply loaded the config I had previously realized. the work proceeds but to be faster I need the "my" proe, the one with which I worked several years, i.e. wf3. Well, I install it. Obviously, as I already knew, it does not open me how much created with wf5. I read a gry plugin if I'm not wrong. but I also read that you must be in active maintenance (which I do not have) and that a basic user cannot download.
I thought. can you install on one pc two versions of proe?? specifically the two listed before?? is there a possibility, as for autocad, you save or .asm and so on with an extension such as to be able to open them with older releases?? Is there an alternative? ?
It is very important, so I thank all those who will help me.
rectifying!! I managed to open the overall, obviously losing all the references of the features, reports etc... major problem... I had done drw... and more importantly, of course, losing the feature references to make a drw you must necessarily put the quotas manually (which is not very convenient)
we have talked about it several times in the forum, if you do a search you will find it but the cgri allows the opening of files without passing from other formats (neutral) and some other little thing, but you can not change the feature tree model, etc.
the interface in the wf5 is changed only in the table, for the rest it is equal to wf3 so I highly recommend you use the wf5 not to poke in all these problems and maintain the association as you had in wf3, with a little patience you will manage to do everything and complete your work.
Good job. greetings
