jim78b
you should help me please, they gave me files in which it says they are incompatible etc etc ok I open them...but the problem is that I have already reinstalled 2 times autocad mechanical 2013 , it loses me in start loading 6 file lisp that I usually use and tells me:
loading model dlls.
opening an autocad 2007/lt 2007 file format.
substituting [SANSS___.TTF] for [sas_____.pfb].
regenerating model.
this drawing was created in language 'ita' with translation information. before working with this drawing you should translate it into system language 'enu'. working with the untranslated drawing may delete the translation information.; error: malformed list on input
autocad menu utilities loaded.malformed list on input
command:
autodesk dwg. this file is a trusteddwg last saved by an autodesk application or autodesk licensed application.
command:
command: rt unknown command "rt". press f1 for help.
loading model dlls.
regenerating model.
command:
command:
