Dottor_Scott
Hello. Sorry if I didn't show up, I'm probably reluctant
but in the subforum 'autocad' I don't see a post where I can do it. I do it here:
designer with 20 years of experience in multiple fields, especially machine equipment. pieces
and special tools; I used autocad for many years, but now the work is done for a 70-80%
with solidworks and ultimately with nx 9.0
My problem:
have passed from an old version of autocad lt (97) to a new (2013)
and no longer takes the apparent intersection. I'll explain: in the object snaps
by default I obviously set to recognize intersection and apparent intersection
by default.
then:
first
selecting an intersection, without selecting anything else, the crucible appeared
relative. also for the apparent, in fact not having other snaps (end, close, etc...)
going on a line without intersection, without selecting anything gave me the crucible
with the dots (waiting the second click for another object)
Now, intersez is fine, but the apparent one does not work: I approach a line for example
without intersection but nothing appears to me. I have to make the window appear
of all snaps, select apparent intersez, and here is the crucible with the dots.. .
Don't you know if you can set up like before? thanks to possible answers
My problem:
by default.
then:
first
