application loads analysis fem
  • Thread starter Thread starter krissbetarr
krissbetarr
Hi, guys! I spulved some discussion but I didn't find anything to help me. I have to perform a fem analysis on a piece 3d (a beam). I must therefore apply loads in precise positions. the problem is that in the fem module of inventor it is not possible to fix the position of the loads or better it is possible to select only the surfaces and the load is inserted accordingly in the direction perpendicular to the face. my idea was therefore to do sketches (e.g. a rectangle) on the beam in the areas where we have to apply the load and then make them surfaces. I don't know if it's correct and even if it were I don't know the command to make a sketch a surface (I read a fantomatic "hole closure" which, however, on inventor 2018 I don't find!). Can I help?thank you
do a sketch on the solid part where you apply the load by delimiting an area, for example with a rectangle.
Divide the surface using that sketch, in that way you will have the solid in which you will find a portion of a surface that you can select to apply the load.
Thanks for the answer. from the street I ask two more questions:
- How do you do in inventor to keep a command "premute"? in caia, for example, to keep a command selected, for example line, it was necessary to double-click on the icon. Is there something similar in inventor?
How should I model, in a fem analysis, a bolted link between beams? Is it possible to use a fastening or a hinge to take into account the deformability of bolts and beams?
thanks in advance
You mean to repeat a command several times?
click the button, for example line, click the line, button dx appears a menu with some options, at the top repeat the command.
for the second question I leave the ball to whom it is more hardwareated than me in matter of analysis fem
thanks in advance
even if you snap the space repeats the last command
