application to open file caia
  • Thread starter Thread starter Ragnarr
Ragnarr
Good evening, everyone. I have files saved with catia v5 that have .catpart or .catproduct extension and mistakenly changed from file property the catia application to open it.
Now I no longer see the catia program among the recommended apps to open these files and I have no idea which of the many catia applications found in c:\program files\dassault systemes\b27\win_b64 is the right one to open the file. Can anyone help me?
but normally the files of catia v5 open them after starting the program.
In this way you will also start a caty v5 session correctly with evtl settings you defined and not those by default dassault systemes.
Let us know
Sorry, I omitted that opening the file after booting cat through "open" from files, everything works properly. but for a quick start, I would often need to open the files directly with double click and start caia then with the opening of the file or anyway open the file with double click also with catia started. for this I would like to know the right application to open the project.
but what strange question,just look at what file refers to the link with icon you have on your desktop
catia v5 is not word or excel.
I suggest you start caia v5 and below open the desired files.
caia connection on the desktop, opening the file path leads to the catstart.exe application that is only the app that starts caia but not the one that is used to open the files.
I understand what you mean, you're right, but I repeat to myself it would be necessary to find a solution to this problem for practicality issues.
Dovrebbe essere
c:\program files\dassault systemes\bxx\intel_a\code\bin\cnext.exe
