cersil
I realized that you can tie the odds by equations, but I can't do the same with the extrusions. I created a hinge, the axieme consists of the two half hinges and the pin. I created it by extruding a base circle. Now I have tied between them the half hinges through equations, so that if for example increase the length of a half hinge the other consequently extends the same size. but aim is the pin!? I want him to adapt to the new length. the fact is that in this case I do not have a quota for the length of the pin but I have a length of extrusion. entering the extrusion property I can not introduce an equation where you go to set the length of the same when it is set blind, accept only numbers not certain equations. how can you change the extrusion length to vary a quota?
thanks for the possible answer.
